rockman7892
- Apr 7, 2008
- 1,176
On several projects recently I have come across Main Lug Only (MLO)MV switchgear located on the secondary of transformers in unit substations. I'm assuming that the omission of a main breaker in many of these cases is due to cost and perhaps in some cases available switchgear real-estate.
Are there any major issues or things to consider with the omission of the main breaker in these MV switchgear lineups? I have also seen similar applications on Medium Voltage Control lineups.
Most of these applications did have CT's in the incoming section of switchgear that were part of a transformer differential scheme or had both CT's and a relay in incoming section that transfer tripped an upstream breaker on transformer primary. I guess these secondary CT's in both of these cases act as a "virtual main"?
