Rick_Australia
First post after really a long time.
I am designing an aluminium access platform usually called mobile platforms or truck access platforms specifically.
I have come across an interesting problem regardless of the actual load carrying capacity of the stairs or the working platform area.
The problem I have is the overturning stability of the whole structure under min. horizontal handrail/guardrail load of 0.6kN.
The whole platform weighs only 200kg, say 200/4 at each support point is 50kg.
The platform is 1.4m high above ground including castor height. The handrails are another 1m top of the platform.
AS1657 is the relevant standard for the Fixed platforms here in Australia.
The platform I have is not per se a fixed platform, it is movable but the castors will be locked on during operation - Still I don't think it is equivalent to a fixed platform attached to some permanent structure.
No code or the standard I have across talks about the platform stability under the handrail loads probably due to the statement above (Fixed to a structure, like you cannot overturn a concrete structure by just putting hand rail loads on a balcony).
But the structure I have is different. These units are quite extensively used through out the world and all have hand-rail safety features.
The issue is I don't understand what's protecting the unit to go off ground in case there is a code-prescribed hand load of 0.6kN?
The only reason I made up is that it is very difficult for a person of let's say 75kg to exert a horizontal force of 60kg.
Also, if there is an accident it is more likely an external accident, like a worker being hit by a steel beam while unloading it from the truck to this platform.
In this case, the hand-rails might protect the worker or at-least help reduce injury as the platform might want to topple over but may get stuck in something like with the body of the truck or something.
If I go with this logic, then hand-rails on this type of structure are a subjective matter, they might protect a falling worker, might not.
I cannot find any other relevant code for this type of structure. I guess it comes to the actual on-site risk assessment of the type of work, if it is risky, contractor will need to fix the platform with the ground slab through a scaffold tube and mechanical anchors or similar.
The codes only mention testing the hand-rail structure for the elastic deflections etc, so the hand-rails don't come off the structure they are mounted to. Like in a balcony or a fixed platform/ramp etc.
I have also attached an image of the forces involved to make my point that there is no way the stability is ensured with this type of loading.
Any thoughts or experiences or suggestion you would like to share?
