  • Congratulations Danlap on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Modal analysis with loads
izyk
21
Hi
I dont know how to perform a modal analysis with loads. I'm trying to find modes frequencies of membrane under pressure but applying a pressure changes nothing, membrane still oscillate around zero deflection. I know that constant load doesn't change frequencies but later i want to apply an electrostatic pressure which changes modes frequencies.
load can affect modal results because of the "stress-stiffening" effect (e.g. tension on a piano wire).
However, the way to do this is conceptually the same in WB and Classical:
- first run a static analysis. In Classical, be sure to activate "calculate prestress" in the analysis options. In WB, choose "modal analysis" in the "further analysis" dropdown list.
- then, without exiting /Solution (in Classical), choose a "new analysis -> modal" and make sure to have the "use prestress data" activated. In WB, choose your previous static analysis from the dropdown list as the prestress condition for the modal analysis.
ok, it worked but i obtained results different from theory.
I'm simulating a circular membrane clamped on edge without damping, large deformation and stress stiffening. Such system can be expressed by following formula:
mw'' + Kw = P*S
where: m - mass, K - spring constant, P - external pressure, S - area
Since external pressure is constant the modes frequencies become constant. In theory for specific dimensions and material properties i got first mode frequency = 8.8991e+005. In ANSYS 8.8748E+05. But when i applied a pressure the frequency increased i.e. P=0.4bar f=0.88880E+06, P=4bar f=0.10103E+07.
Where is the difference beetween theory and ansys?
Here is the script:
FINISH
/CLEAR
/FILNAME,memcir50shell,0
/CWD,'C:\temp\ANSYS'
!* membrane
Rad=150
Tm=5
b=30
/PREP7
ET,1,SHELL63
R,1,Tm
MP,EX,1,169e+9*1e-6
PRXY,1,0.0625
DENS,1,2330*1e-18
PCIRC,Rad, ,0,360,
LESIZE,ALL,,,b,-5
MSHAPE,0,2D
MSHKEY,1
AMESH,ALL
!* applying loads and BC
FLST,5,4,4,ORDE,2
FITEM,5,1
FITEM,5,-4
LSEL,S, , ,P51X
NSLL,S,1
D,ALL,UX,0
D,ALL,UY,0
D,ALL,UZ,0
D,ALL,ROTX,0
D,ALL,ROTY,0
D,ALL,ROTZ,0
ALLSEL,ALL
SFA,1,1,pres,40000*1E-6
/SOLU
ANTYPE,STATIC
PSTRES,ON
NLGEOM,OFF
SSTIF,OFF
SOLVE
FINISH
/SOLU
ANTYPE,MODAL
UPCOORD,1.0,ON
PSTRES,ON
MODOPT,SUBSP,5
EQSLV,FRONT
LUMPM,0
MODOPT,SUBSP,5,0,0, ,OFF
RIGID,
SUBOPT,8,4,9,0,0,ALL
SOLVE
FINISH
save,memcir50shell,db
fini
the difference is that the K terms depend upon P, i.e. Kij = fij(P). In addition, you say you wanted large displacements and stress-stiffening, but the script shows that both are OFF (by the way: are you sure you do need Large Displacements? L.D. at 500 [kHz] should require an enormous amount of energy!).
In other terms, I think you are comparing FE and handcalc results with two different formulations, one less complete (handcalc) than the other, and there is a little confusion between what you did and what you wanted to do ;-) !
Ok, i didn;t know that for plates K depends upon P.
But now i can't receive results for electrostatic pressure. Because of unsymmetrical matrices i have to use unsymmetric extraction method. But it gives no results in results summary. The same for a membrane without load.
p.s. i don't want LD
FINISH
/CLEAR
/CWD,'C:\temp\ansys'
!* membrane
Rad=150
Tm=5
!* membrane_division
b=30
!* electrode_distance
h=-1
dif=20
!* voltage
v=5
/PREP7
ET,1,SHELL63
R,1,Tm
ET,2,TRANS126
MP,EX,1,130e+9*1e-6
MP,DENS,1,2330*1e-18
MP,PRXY,1,0.278
WPOFFS,0,0,dif
PCIRC,Rad, ,0,360,
WPOFFS,0,0,-dif
LESIZE,ALL,,,b
TYPE,1
MSHAPE,0,2D
MSHKEY,1
AMESH,ALL
!* transducer
NSEL,S,LOC,Z,dif
CM,tr,NODE
ALLSEL,ALL
EMTGEN,'tr','EMTELM','EMTPNO','UZ',h,0,1E-02,0.8854E-05
NSEL,S,LOC,Z,dif+h
D,ALL,,0,,,,UZ
D,ALL,VOLT,v
CMSEL,S,TR
D,ALL,VOLT,0
FLST,5,4,4,ORDE,2
FITEM,5,1
FITEM,5,-4
LSEL,S, , ,P51X
NSLL,S,1
D,ALL,UX,0
D,ALL,UY,0
D,ALL,UZ,0
D,ALL,ROTX,0
D,ALL,ROTY,0
D,ALL,ROTZ,0
ALLSEL,ALL
FINISH
/SOLU
ANTYPE,STATIC
PSTRES,ON
NLGEOM,OFF
SSTIF,OFF
SOLVE
FINISH
/SOLU
ANTYPE,MODAL
UPCOORD,1.0,ON
PSTRES,ON
MODOPT,UNSYM,5
EQSLV,FRONT
LUMPM,0
MODOPT,UNSYM,5,0,0, ,OFF
RIGID,
SOLVE
FINISH
fini
