Modelcheck
rajeshrs
Automotive
May 5, 2008
5
Could someone give me a brief rundown on what PTC ModelCheck does when it checks models and what kinds of inputs and outputs are there in PTC ModelCheck?
Any help will be appreciated.
I have only used model check when surface modeling. In that case it identifies possible points of failure for solidifying.
ANormand
Thanks for your response. I too use Pro/Surfaces quite a bit. Would you happen to know how to configure ModelCheck using the config files?
Thanks in advance
Send me a private email as I have a ModelCheck tutorial on how to set it up.
Ben Loosli
