SKSA
- Feb 28, 2024
- 33
Hi there,
I was trying to model a cut soil to simulate the basal heave in narrow braced excavation. Here in this picture I used steel plate. After running the simulation the steel plate has moved down a little bit which is not acceptable. I used bottom point fixed in the steel plate. The soil material is clay. What could be issue? Can you please give your suggestion from your own?
