Hi
I have a general question on whether to use Compression or tension test data for plastics in FEA modeling? I have come across couple of PTFE based plastics where compression modulus is twice as much the tension modulus. For metals I observed it would be nearly the same so doesnt matter which to use. However, for PTFE plastics which one to use? In the past, I have looked at the part whether it is loaded in tension or compression and have used appropriately. But I still am not satisfied and am looking for some concrete procedure. I am more towards using tension data as it is more conservative and I can determine the failure by looking at my strain or stress levels and comparing to the ultimate limits. For compression, this seems to be limiting factor.
Please throw some suggestions.
FM
FM
