Hi everybody, I'm a last year architecture student passionate about contemporary techniques of stone building. I'm trying to model a stone arch, made by several voussoirs and reinforced with internal cables: I've read that the contact between adjacent voussoirs may be modelled in Strand7 by using point contact elements, but what about the internal cables? Is it possible to somehow simulate the epoxy interface between the cable and the internal surface of the hole drilled in each voussoir; is it possible to assign a pre-tensioning to the cables and how do I decide its value? Moreover, given a 3d model imported from Rhino, is it necessary to manually connect every single node of the adjacent contact surfaces in order to simulate the compression only behaviour of mortar? Hope you can help me and thank you very much in advance
