Hi There,
I intend to make use of a flat plate slab (approx 300mm thk) on ETABS so that I can use this as portal frames with my columns to resist lateral loads. (Note not the conventional beam and column system unfortunately).
If I were to model this on ETABS what would be the best way to do so?
I'm thinking of either creating frame elements with an effective width of a column strip with slab modifiers set to 0.4?
Or keep slab modifiers to ~0.4 and let ETABS distribute the load out?
What are your thoughts / experiences?
