Modelling Multi Panel Slab Concrete with Shell Element
wisnu666
16
hi guys, seems that i need all of your help
im on my study in finishing my under graduate final project. my study is about concrete slab element moment in multi panel. the panel that i modelled is like this
beside that, i modelled it with patterned load for maximum positive moment like this image below
the BC that i applied in the all edge, is encastre, then i connected every panel with tie constraint. beside that, i boundary condition in every panel to panel connection with U1,U2,U3, and R2 applied.
the problem is, there a moment in mid spand with negative value like this pic. i marked it with red circle
can everyone help me to figure out this? just got stress over last one month :) thanks in advance
Seems like the BC is missing on these two edges. Check that BCs are not ignored, when these nodes are slave within the tie constraint. Check .dat for warnings and check in postprocessing if the BC is used by the solver. There is an option to display icons of BC in postprocessing.
@Mustaine3 thanks for your advice. ill check now :)
