Hi guys,
The geotechnical report is asking to use 4000 psi concrete due to moderate sulfate exposure. I will specify 4000 psi for footings but what about the stem of the CMU retaining wall?
I want to use CMU retaining wall (fully grouted). If so, does CMU block need to be protected from sulfate?
Thank you all in advance. You guys are an amazing group of engineers!
