posture
- Jul 8, 2010
- 21
Hi
I have a question whether it is permissible to modify an RTJ flange so that it becomes a RF flange.
Our project engineer has a problem where a supplier has sent in 1 1/2" 316 stainless steel adapter RTJ flanges when the valves they are being put on are RF. It is a class 150 system but the flanges and valves in question are class 300.
Replacement adapter flanges are on 10 week leadtime so they do not want to send them back.
They have suggested that we fill approx. 2mm of the RTJ groove with weld, then machine the flange face back to the correct raised face depth for a 300 lb RF flange and machine on the required spiral finish. See attached. All minimum dimensions will be met as per ASME B16.5
Is this permissible under 31.3 or other codes? Has anyone on here done this or similar in the past? Any additional precautions that we should take?
Posture
Posture
