bookowski
- Aug 29, 2010
- 983
thread507-504345
Circling back to this thread.
@Warhamer
- Can you clarify where I could find the modular codes that you are referring to. My projects are not in any of the states that you mentioned, but I'd be interested in looking at those codes anyway to see if there's anything useful. I haven't found the codes that you refer to. I found this on the MBI website "While there is no modular code, our industry does have is a series of administrative rules and regulations, and in some cases guidelines and standards in place. But in terms of the building itself, our industry constructs to the same applicable building codes as our site-built peers."
- I did find a California "factory built housing program", is that what you are referring to? I didn't dig too deep into it but on a first pass it seemed to refer back to the standard codes for structural design. "The design and fabrication of factory-built housing shall be in accordance with the applicable building standards contained in Parts 2, 2.5, 3, 4, 5, 6, and 11, Title 24, California Code of Regulations"
- Is there anything in the codes that you reference that is more restrictive than IBC/AISC/ASCE7? This project is in a moderately high seismic area so the designer (in EU) is currently working with aisc 341 for the steel design.
- A comparison of S355 to A572 indicates that their properties are very similar (at least in terms of Fy, Fu, elongation, and pretty close on the max content of various elements) but I have not made any headway on getting an approval from the ahj so the supplier is looking at testing.
@Warhamer
