Is anyone familiar with Carrier's Moduline system? Is this a constant or variable air volume system? I've heard it can be either but cannot seem to find any confirmation.
If I understand this correctly, the constant volume systems are equipped with a bypass damper that re-circulates the air into the plenum when the space does not call for cooling.
If the modulines are equipped with a bypass damper, would they work with a supply fan equipped with a VFD? What would be the ramifications?
Thanks!
Thanks!
