transmissiontowers
- Jul 7, 2005
- 561
ASTM A475 lists the properties of several types of galvanized stranded cables used for guy wire. I was looking for a reference for the modulus of Elasticity (MOE) of these cables. It should be less than solid steel rod since as you load the cable it unwinds the individual strands a little and it probably depends on how much load is applied.
To further complicate matters the ASTM A475 lists the diameter of the strands with galvanizing and calculates the cable area including the galvanizing thickness (I think). Since zinc has a different modulus than steel, will the effective cable modulus be dependent on the steel area or the total stranded area?
_____________________________________
I have been called "A storehouse of worthless information" many times.
