dan00
- Apr 22, 2005
- 16
We determined the moisture content of frozen marine sediment samples, but the results seem to be higher than some previous testing (average about 20% higher). Is any correction that needs to be applied for salts? Or is there a standard procedure for moisture content of marine sediments? Samples are kept in the freezer in sealed containers. Could the difference in freezing temperature generate the difference in moisture content? Thank you
