I was wondering if anyone could help me with my design of the mentioned sieves. Having sized and designed two sieves in parallel for a 100,000te p.a. ethanol plant, and with no small scale lab to model their operation, I need to know for sure if they will dry the ethanol sufficiently. Input is 95%(by mass) ethanol, output is 99.7%(by mass) ethanol.
Conditions are 150oC and 2.7bar, and operating cycle lasts 10 mins. Are there any ways of checking? The isotherms I have modelled this on are minimalistic.
Regeneration is with CO2 at 200oC and 2.2bar.
How should I scrub excess CO2 from the bed after regeneration before putting it back on line?
Also what material is used to build these things? I presume some kind of stainless steel?
