Hi all,
The examples of bolted connection I could put my hands on are showing end of steel beam bolted to a steel column in a vertical manner.
My question is, given a situation where a square steel frame, loaded in all four sides, vertical loading is higher than the lateral loading, is it not better the bolted connection to be arranged in horizontal manner as compared to the typical vertical arrangement shown above?
