hungrydinosaur
Marine/Ocean
- Sep 25, 2013
- 41
We have a 12 ft W Beam running in our workshop, with a 2 ton trolley running in it. Everything is rated for a WLL 2 ton. The W Beam is welded across to the transverse beams above it. All the transverse beams make up the roof of the structure, and all the transverse beams are placed at a distance of 3 ft apart. We are planning to lift a load of 2 ton, but now planning to use 2 trolleys, instead of one.
Will this arrangement (lift by 2 trolleys), have any effect or increase in the loading on the W-beam or on the roof structure/transverse beams above it? Now the point load on the beams is halved, in this scenario with the use of 2 trolleys. Do we need to have some minimum spacing between the 2 trolleys?
Thanks in advance.
HD
Thanks in advance.
HD
