I want to build a manure application bar with an integrated compressor for cleaning out the drag hoses by pushing a foam plug from the field back to the storage pit. What's a simple, compact and inexpensive way to generate 300 cfm at 50 psi powered by a 1000 rpm tractor pto shaft?
One thought was a vane compressor but the ones used on sewage tankers and such are often only rated to 20 psi output. Higher pressure ones often require external lubrication and cooling systems which is no longer simple or compact.
Another thought was an old engine with custom built heads but I'm struggling to find a good source for suction and exhaust valves.
Thanks in advance for your ideas!
