Sumair786
- Jul 24, 2022
- 21
Hello everyone,
I have rewind a Seimens motor 250KW with exactly same data as original and motor is consuming higher ampere against original, motor details are
Atlas copco compressor
Rated ampere 445 as per name plate
Current ampere on start initially it was 515 the. Slowly rising and now it is 540 and temperature rising too i don’t have much knowledge about compressors so i need some expert advice anymore details you need I’ll provide ASAP
Thanks alot
Thanks alot
