NickParker
- Sep 1, 2017
- 444
My specification says, The NDE bearings for motors frame 225 and larger (≥30kW approximately) shall be insulated to prevent bearing currents. The bearing insulation shall be performed by insulating the
bearing seat on the motor shaft or through the use of current-insulated rolling-contact bearings.
Vendor is offering the NDE bearing without insulation and the reason he says that since Y-D starters are used, insulated NDE bearing is not required.
My question is, how the Y-D starter prevents the bearing currents?
