Motor Bearings Overheating at 60 Hz – Seeking Expert Advice
Capetowners
1
Motor & Pump Overheating Issue at 60 Hz – Need Insights
Motor Specs:
  • 3-phase induction motor (440V, 60 Hz, 62A, 42 kW, 3555 RPM)
Issue:
Our pump runs fine at 50 Hz, but when switched to 60 Hz, the motor bearings overheat. The motor is coupled to the pump via a dummy shaft, and all bearings are new SKF units.
Questions:
  1. Could the motor’s rated speed (3555 RPM) being close to synchronous speed (3600 RPM) be causing overheating?
  2. What adjustments can mitigate this issue at 60 Hz?
Thanks y'all in advance
What flow/head is the pump running at? It looks like an OH5 style pump, so the motor bearings are carrying all the thrust loads of the pump. I'd say that the higher speed is overloading the motor bearings.
More important than over-greased, what is the base oil viscosity of your grease? Are you using a polyurea grease or a lithium grease?
SKF isn't calling for Kendall L-427 Super Blue grease are they? If so, that's definitely your problem.
Remember, high temp grease make bearings run hotter. If you want your bearings to run cooler use low temperature greases.
Why are you using split lock washers? They have no purpose other than to cause failures and increase inventory loads.
Is the pump designed for 60 htz operation? Power goes up by a factor of pump speed ^3. So this is 70% more power at 60 htz than 50 htz. Does that have an impact maybe?
