Jk1996
- Mar 14, 2021
- 70
Right I have another question. I have a case where there are two separate pump panels both individually isolated. What I want to do is run both pump control (start signal 110vac) into an outside enclosure and then use this signal to create a start stop and e stop circuit. Is it a problem running these signals to a common enclosure? Obviously to isolate that panel both pump panel isolators will have to be switched off. What are your thoughts. Thank you in advance guys
