I am interested in motor cooling.
1) What's the key component in motor (induction motor) heat generation? is it the current (amps) or the input horse power and efficiency at a specific point. I read different articles and they all mention current losses in the motor (stator and Rotor), but they don't mention if all these losses are converted to heat.
2) Also if a 50 hp motor is 90% efficient, what's the heat generated? Is it the 10% loss?
3) In addition with VFD there is a change in voltage, frequency and speed but the input current could remain the same so how that affect the motor cooling. This related to the first question; if the voltage/frequency is constant but the current change with load does this affect the fan if is speed independent.
4) In case of speed dependent or independent ventilation, what's the best setup to get the appropriate cooling?
Thanks in advance for your explanation
