Motor estimators 3
stevemechanical
47
does anyone now a web site that has motor hp, fla & lra info?
I think you can try any motor manufacturer. I assume hp = horse power, and fla = full load amps, but what does Ira stands for? And what kind of motor? DC, AC, single phase, three phase etc, etc?
For a start search "electric motor" at:
Most motor-manufacturers will have their motor-data on the web. I was not always able to find the LRA of a motor on the web, but certainly the manufacturer will provide you with the info if you contact them.
The LRA of a motor can range between between 500% and 1400% of the FLA, and for a good motor between 550% and 750%. As a rule of thump you can take the LRA to be 600% of the FLA.
I hate tagging onto existing threads, but it seems close enough in this case.
Anyone know of good sources like this for Medium Voltage IEC motors? I find it easy to get info on motors for North America, but difficult to find things like motor FLAs, pf, etc for MV motors used in other parts of the world. I know that 10kV and up are usually made to order, but I am looking for info on 3.3 and 6.6kV common motors. Any ideas?
"Venditori de oleum-vipera non vigere excordis populi"
jraef,
I've checked all the motor-manufacturers I'm familiar with who supply MV-motors in South Africa. (an IEC-country) Unfortunately I found no such data on their web-sites, the best would be to contact them and then to ask for the necessary information. Manufacturers who I'm familiar with are:
ABB
Siemens
Alstom
Zest (for WEG)
This is from a South African viewpoint. Maybe there are other IEC-manufacturers, but I am not familiar with them.
Hope it helps
Ralph
