dirtyc7
- Dec 13, 2016
- 2
Please see the inserted image of a small 3-phase motor name plate:
I do not understand what the R1, R2, X1, X2, XM terms mean. It seems like the R1, R2 are the number of ohms I should see if I measure from phase lead to phase lead (while disconnected from power source, of course).
However, why is there only 2 of them if there are 3 phases?
tt
My motor has 9 wire leads sticking out of it. When I measured them all (T1 to 2, 3,...9. T2 to 1, 3,...9 etc) I found that T1-T4, T2-T5, T3-T6 all measured 4.8 ohm each. Any combination of T7,8,9 measured 8.9 ohm.
Outside of those measurements, all other leads to each other were in the megaohms
The measurements between motor leads suggests, per the chart below, that my motor coils are a wye-style load.
But, even if that is true, why I don't I get the 10.8 ohms on the name plate? if there are 3 phases, why is there only R1, R2? What even ARE X1, X2, Xm?
tt
