Motor size
Lan123
155
How can I determine the approximate motor size for a sewage pump that has an operating point of 6600 gpm @ 6 ft. The pump speed is 330 rpm. The pump manufacture's bhp curve shows a maximum value of 170 at startup, and, 130 at the operating point. The pump efficiency at the duty point is 86%.
Suggest you post the pump curve, as this flow and head is nowhere near 130hp - or am I missing something?
If the pump manufacturer's curve shows 170hp at startup, one would think that you'd want more than 170 hp motor.
Unless you don't plan to start the pump.
I would say that you can't see the decimal in the hp scale; I'm willing to bet that it goes from 0.0 to 18.0 hp, not 180...
This is a typical mixed / axial flow pump curve, as you sure it's suitable as a sewage pump.
The power you suggested is out by a factor of 10.
The starting power is not (170hp) 17hp - this is the power if operating at maximum head and zero flow not a starting condition.
Thanks folks for all the feedbacks. I have requested the vendor to provide me the motor information. I will let you know when I heard back from him.
