Mounting spring loaded battery contacts in the enclosure.
Zabee.Khan
Hi All,
I wanted to know how can i mount a spring loaded battery contact in my plastic enclosure?
attached is the type of connector im using.
Should i mount it onto a pcb or not needed.. i wanted to know if i could mount a similar type of connector without using a pcb board.
Zabee
It doesn't simply mount to a pcb, that's how it is connected to allow the battery to function. If you need some other mounting method more information will be required.
