Mouse Button Programming
sams
34
I am working in Autocad LT 2007 after a long break.
When I launch a new drawing or open an existing drawing
the left button is pre programmed to prompt for next point of a window.
I want to reprogram the left mouse button for enter key.
Would any reader of this forum, please show me where I can find the instructions for programming mouse buttons?
Sam
Hiya Sam,
If you're using Windows XP, I don't mean to sound patronising, but have you checked that the Start / Control Panel / Mouse Properties dialogue box's first Tab (Buttons) has all the boxes on it un-ticked? This can switch between the left and right mouse buttons, you might want to experiment with this option to get your left key acting as enter.
I use an AutoCAD 2005 version (for my sins), if 2007 is similar, then the only route I know for changing the settings within the program aswell is Tools/Options/'User Preferences' tab/Right Click Customisation. You might want to check that on the 'User Preferences' tab, both the 'Windows Standard Behaviour' buttons are ticked.
On the 'Right Click Customisation' dialogue box - check that right click doesn't mean ENTER you can change Pan settings by typing 'mbuttonpan' into the command line
Same question - sort of:
Upgraded from 2006 to 2008. The new right-click default wasn't what I wanted, so followed the above procedure. Now works fine except:
1. I want Properties to be on the shortcut menu that pops up.
2. When text is highlighted, I want the option for text edit to come up.
Anyone know how to set it?
Thanks,
Also, for the mouse wheel ... go to Tools/Options, under "Window Elements" uncheck the box for "Display scroll bars in drawing window" then "OK". You can them zoom within a window using the mouse wheel.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Autoangst, Geof, ctopher
Thanks for your replies
saludos
Sam
