Move Assembly relative to default coordinate system? 1
gearhead01
6
I am trying to work with a large assembly that was created from a scanned surface. When the assembly was created, the coordinate system chosen seems to have been totally random. Is there a way that I can move and rotate the assembly so that the x,y,z axes of the assembly align logically with the coordinate system? I have an origin, centerline plane, transverse plane, and ground plane in the assembly. How can I move the assembly to align these planes with the coordinate system? Thanks.
Another note:
When I try to move or rotate the assembly, I get the following error message:
"The selected component is fixed. It cannot be moved."
First Post ... Change coordinate system in Solidworks? thread559-136322
Second Post ... RMB click on the assy in the FM & select Float
[cheers]
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Thank you very much! I had been beating my head against the wall with this for a couple of days. Your suggestion worked great.
