Hi! I am an engineering student and I am conducting a buckling analysis of a panel. All the nodes of the bottom side of the panel are fixed, I apply a forced displacement to all the nodes of the upper side of the panel and the analysis with SOL400 runs normally.
I want to create a Load/Displacement graph so I then tried to use RBE2 MPCs to apply the forced diplacement to one Node and constrain the movement of the nodes of the upper side in respect to that independent node so that I can measure the constraint forces on that node. Using RBE2 MPCs the analysis with SOL400 finishes but the results are problematic.
Is there a problem with the use of RBE2 with SOL400? Is there another way to measure the total constraint forces in order to create the Load/Displacement graph for the panel buckling?
