MRP pipe 2
ercanbaser
29
Is there anybody who knows about MRP (metal reinforced corrugated pipe)? The pipe is like double wall HDPE corrugated pipe but there is a metal layer inside the pipe.
ASTM code : ASTM F2435 - 05
I want to know about your experience and views (positive or negative) and the advantages of these pipes with respect to DWC (double wall corrugated) pipe.
Thanks...
I have used large SRPE Steel reinforced polyethylene pipe on a project recently. The product used was not double wall, it was single wall, smooth not corrugated on the inside. Steel ribs on the outside.
pros
- thin pipe wall allows larger pipes to be used in narrow areas
- gasket provides relatively good seal
- smooth interior
- lower installation cost
cons
-pipe deflection when backfilling
-must hold down the pipe while backfilling or it moves
-difficult to make connections without manhole or encasement
thanks cvg.
Could you tell the brand name of this pipe?
An ? would like to know that what was the stifness value of pipe? In which system did you used this pipe (sewer?) ?
