I am getting the error 'Operation must use an updateable query.' when I run an update query with subquery in MS access. Here is an example of the query:
UPDATE MatMonData SET MatMonData.prodHeadID = (
SELECT ProdHeader.prodHeadID
FROM ProdCalendar INNER JOIN ProdHeader ProdCalendar.prodCalID = ProdHeader.prodCalID
WHERE prodCalDate=matMonDataDateTime And wcName=matMonDataLineNo
WHERE MatMonData.prodHeadID Is Null;
As you can see I am using a subquery to populate a field with the relevant number (which happens to be a foreign key). The reason for this is I am importing a flat file, where the information is organised in the database in mulitple tables.
Not sure if this is enough information - let me know and I can supply more if needed.
Thanks for your help.
