you might want to take a look on following books:
- Designing with geosynthetics, by Robert M Koerner
- Soft Ground Improvement in lowland and other environments, by Bergado, Anderson, Miura, Balasubramaniam.
Sure - I've done hundreds - in addition to the above check out Colin Jones' text book.
In the USA be particularly aware of the RECO practice of not considering corrosion at the bolt hole - the assumptions simply aren't realsised in practice and in the rest of the world the bolt hole is considered the weakest point.
