MTBF interpretation 1
Metera
1
If MTBF value is 120 yrs, and 7 units failed out 1200 units, how is this translated in to ppm or % wise?
MTBF is not exactly the right value for predicting the number of failures of a certain amount of units. You'll need to figure the actual probable failure rate to figure failures of parts per million.
MTBF will allow you to predict the probability of a part working based on a certain time. R(T)=exp(-T/MTBF) T is the time you're interested in and R(T) is the probability the part will work over that course of time.
Hope that helps answer part of your question.
- Kyle
Kyle Chandler
"To the Pessimist, the glass is half-empty. To the Optimist, the glass is half-full. To the Engineer, the glass is twice as large as it needs to be!"
What is your physics of failure, is exponential the correct distribution? I agree with the Kyle, you will need to calculate reliability at a given time to get ppm.
You need to also determine whether the MTBF is predicted for the same environmental conditions that the systems that failed were operating in.
A higher ambient temperature could easily double or quadruple the failure rate.
TTFN
FAQ731-376
