dingo16123
I'm working on a project which involves designing an exhaust system for a 660cc turbocharged engine. Most of the research that I've done is for NA engines. I've done some reading on different types of silencers and mufflers. My first question is what are the typical applications for each type of muffler? (ex. helmholtz resonators - low frequency, packed silencers - high frequency)
The other question is what are the characteristics of the exhaust noise compared to a NA engine? I read one post that mentioned the frequencies from a turbocharged engine are mostly high frequency. Is the exhaust noise all high frequency or is there still significant noise from the firing order frequency? I ask this becuase I want to know if I should bother attenuating the firing order frequency also. I couldn't find anything in more depth dealing with turbocharged exhaust design.
Assuming that the majority of the exhaust noise is from the turbo (high frequency), should I be looking at a packed silencer to attenuate the high frequencies? Most of the suggestions I have come across for NA engines is to use a resonator.
Since we are talking about a turbocharged engine I might as well bring up the intake also. What kind of opportunities are there to reduce noise by integrating a muffler in the intake? Are the sound characteristics the same as the exhaust? If so, would adding a packed silencer be the correct approach?
I realize there is no right answer to some of the questions. I am just looking for some advice or suggestions from your knowledge and past experiences. All suggestions are welcome!! Thanks in advance.
