Multi-family residential Partition Load
RFreund
1,885
How do you handle partition loading in multi-family residential?
I could see a few cases:
1. Treat it as a dead load - typically 10psf is what I see. This load would not get reduced as it might for a live load. Most likely this load will be there.
2. Treat it as a live load - 15 psf as noted in ASCE 7. This is typically done in office buildings but because the code says "where partitions will be erected or rearranged" I suppose this could apply to multifamily residential as well.
3. Some combination of the above.
I could see an argument made either way. I mean typically the walls of multi-family residential are not going to move, but they could, just not as regularly as say, an office building.
Thanks!
EIT
faq731-376
I have never worried about it except typically to add a double joist under it if it is of significant length. Let's face it, an interior wall is only 2x4's and 2 layers of sheetrock - so about 6 psf. That gets lost in the noise in the grand scheme of things. I never max out spans in any structure to prevent serviceability complaints so there is always plenty of fat.
I've been using:
-actual weight for demising and corridor walls which usually don't load horizontal framing anyhow.
-5 psf extra on the floor area based on some typical unit plans.
This is something that I wish the codes covered explicitly. Many of my competitors just assume that it's covered in the live load.
Treat as a dead load at the location it is to be installed. Never seen the moveable partition load applied in residential.
I guess I should clarify my post. 6 PSF x 9' height = 54 PLF. The way I look at it, the wall takes up about 6" of floor space with baseboard. - so you could subtract 20 plf of potential live load. Still does not make up for it completely , but close enough in my book. I def. take it into account for seismic, however.
If it's condos, I include the partition load. If it's apartments or dorms, I include it as a dead load. I include the mass of the partitions for seismic regardless. After some debate with other engineers in my office, I agree with XR250 that it washes out with the conservatism of the other loads.
@mike: why the different treatment for condos.
It's very unlikely that an apartment unit will have the wall configurations changed unless it's a building wide renovation, but individual owners of condos may be able to make renovations. We started doing that when we had a high end condo project where the architect specifically told us partitions won't be erected until they are sold.
