Said the Sky
- Oct 1, 2018
- 76
So where I am from the base building engineer for a multi storey regular stickframe building may or may not specify engineered wood beams (LVL, PSL etc), for the most part we "try" to coordinate with the supplier designer with them providing us their shop drawings and we take care of the total building stability in terms of how the gravity loading affects our lateral design. The supplier designer usually provides engineered joist sizes and spacing and usually the engineered beam plies (depth usually governed by architect), they sometimes get to choose the layout themselves, then when we recieve their drawings we see if we can make our lateral work based on that.
per the simpson strongtie hangers - as an alternative to nails they may use longer SD screws that penetrate into multiple plies. Who specifies when to use the longer screws and when to use nails? is it the supplier designer? and per the circled comment in the picture, who supplies the extra fastner requirements at the location of the connection? is this the supplier also? I know for typical uniform loading for multiply beams there fastener tables from the supplier which I doubt the contractor never reads.. and I doubt they would be able to read the charts anyways as it requires calculation of the uniform loading to find the nail requirements. I believe whats more critical is the beam to beam connections where there is a large concentrated load and may require additional fasteners.
I guess my question is, when we have a multi ply beam framing into another multi ply beam, who designs the fastener requirements at the location where the two beams meet. Since in side loaded wood beams we have to ensure there is enough lateral resistance of the fasteners to carry the load to all beams and not overload the one beam.
tia
tia
