I was wondering if someone can help clarify something for me. I previously worked for an offshore GI contractor and designer and have fairly recently moved to onshore work.
I have noticed since moving onshore that many GI contractors adopt the performance of a multi-stage unconsolidated undrained triaxial test with varying cell pressure. My question is, what are the perceived benefits of performing this test over a single-stage test. In my experience I have only ever specified single stage UU tests with cell pressure = in situ total stress, and sets of 3 consolidated triaxials for stress dependence.
As I understand, theoretically the deviator stress at failure should be equal regardless of cell pressure (though in practice this is not always the case, I anticipate this is due to imperfect initial saturation / possible thixotropic effects of shear surfaces).
Can anyone provide guidance as to the rationale for assigning/performing these tests and any advantages the additional stages bring? The issue I have is that these tests are being summarised in this case by apparent cohesion and friction angle values, which I believe are indicative neither of total or effective stress shearing.
Thanks.
Thanks.
