Multi step analysis in FEA
Apoorva Tyagi
Student
Oct 19, 2020
Hello Everyone,
I am running a multi-step analysis for a drivetrain. The first step is used to create a contact between gears by controlling rigid body motions and the second step is used to apply the drive torque.
The question I have is will the stresses that are generated in the first step propagate to the second step or the second step starts with zero stress?
I'd have thought the gears would be in direct proximity but no forces generated after the first step.
Cheers
Greg Locock
Are you talking about Abaqus ? Is geometric nonlinearity enabled ? Is plasticity defined ? Make a simple test to check how the results are carried over to subsequent steps.
Hello, yes. Generally in ABAQUS contact interactions defined in the initial step propagates to the next step
