Hi all,
I'm continuously facing problem for multiphase flowline simulation, Olga simulation giving warning for multiflash failure and fluid update for flow path. File generated with black oil method, well test data GOR=2664, oil 55% and water 45%.
WARNING Compositional Tracking PVT routine for flash and fluid update failed : FLOWPATH=O4P-0_Miltiphase Flow line, PIPE=Pipe-10, SECTION=1. Pressure above maximum value (202500000 Pa). I tried to increase pressure and temperature range to maximum range, even simulation is not going through. Can one let me know troubleshooting of this problem.
