privateer
- Feb 19, 2002
- 27
I've started at a new company that does a lot of compressor stations in pipeline facilities. The company has had a lot of success installing multiple compressors (3 to 5 per) on common concrete block foundations - meaning, lined up in a straight row on the common concrete (3-4 feet thick) foundation. There has been no vibration issues. They even install pre-fab metal buildings on the same foundations (even with bridge-cranes) that cover the compressors, without any vibration issues in the structures too. The compressors used are in the 5000-6000 HP range, weighing 110,000-140,000 lbs. (entire package, including the structural skid).
My project manager asserts that this is the way he has always done it, and has had success for about 30 years this way. As a design engineer, I do not dis-believe him - actually I would like to prove him correct somehow (it's not enough to be successful, I need to understand WHY/HOW we are successful..)
I have done compressor foundation analysis before, but by no means am I an expert. But the foundations I have done were a single compressor on a block foundation, and the overhead structure foundation was separated (separate column footings and isolation joints..)
In my research, I have found no design guide to address multiple compressors on a common block foundation, other that several "references" that comment that this is actually a favorable condition - that the vibrations "cancel" or dampen because vibration frequencies are scattered by the multiple machinery running at the same time....
Any thoughts/comments/ideas....????
