Dear Folks;
In SW2005 I have modelled a 3" header pipe with a series of 1" pipes welded perpendicularily to it.
The 1" pipes are controlled by a linear pattern. The idea is to vary the number of 1" pipes from 1 model of heat exchanger to the next.
On my drawing sheet, I insert model dimensions and have a dimension going from the first 1" pipe centerline to the last 1" pipe centerline.
What I would like the dimension text to show is the following: "x equal spaces @ y" = <DIM>"
I would like to insert dimension variable names from the linear pattern into the text so that the "x", the "y" and the "<DIM>" update as the number of pipes is changed.
Any ideas on how to accomplish this ?
Best Regards
Adrian Dunevein
Best Regards
Adrian Dunevein
