Hi .
For a multiple earthed network(the neutral wire is earthed at the powerhouse, at the point of supply to each consumer and at other points along the line between powerhouse and consumer), I have to use 3 p ACB, that's clear.
But designer wants Ground fault. And CT on neutral.
I know ground fault works like this: is adding all currents in the 4 wires, and vectorial sum different than 0 initiates trip.
Or, in this case... All the time vectorial sum is not 0, since we got earth links everywhere.
Final question: ground fault not applicable to multiple earthed system?
