johcatrac
- May 3, 2008
- 43
If I use more than one gasket at a bolted joint, will it impact the torque to be applied? i.e. will the torque be greater with 2 gaskets as opposed to that with a single gasket? I would appreciate any input.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
johcatrac said:Thanks. Can you please indicate a couple of Codes that prohibits this?
