  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Multiple Holes Normal to Surface Macro 2
jzecha
Aerospace
Jan 20, 2016
236
I am looking for a Macro that will create 100+ of the same hole normal to a complex part surface.
I start with hole axises, but I can intersect those with the part surface to create intersection points.
I have searched this forum and found references to PKT license, which I do not have.
I have been running CREO most of this year and I have gotten used to its easy ability to pattern 3D holes.
Well I am in the process of migrating this code to VBA and updating it with some of the features listed above and have run into a problem.
Does anyone know how to create a hole from an intersection?
I have created planes and intersections for exactly what i want.
I have tried to use this code:
Set hole1 = SF1.AddNewHoleFromPoint(Coord(0), Coord(1), Coord(2), reference4, 10#)
but i can't get it to work correctly.
Can someone tell me how to reference the coordinates from my intersection points?
Here is how i have created my intersection
Set hybridShapeIntersection1 = HSF.AddNewIntersection(reference1, reference2)
put a datum point on top of your intersection... and get its' coordinates
Dim coord(2)
Dim TheSPAWorkbench As Workbench
Set TheSPAWorkbench = CATIA.ActiveDocument.GetWorkbench("SPAWorkbench")
For Each myHybridShape In hybridBody2.HybridShapes
Set mydatumpoint = hybridShapeFactory1.AddNewPointDatum(myHybridShape)
Dim TheMeasurable As Measurable
Set TheMeasurable = TheSPAWorkbench.GetMeasurable(mydatumpoint)
mydatumpoint.GetCoordinates coord
Dim hybridShapeLineNormal1 As HybridShapeLineNormal​
regards,
LWolf
Actually, you don't need to create additional datum point, GetCoordinates determine actual geometry automatically.
What you need to do us to call Compute prior to GetCoordinates.
I got LWolfs solution to work, thanks for the direction.
Little Cthulhu, I can figure out how to get your solution to work, can you please give me a little direction what I am doing wrong?
Here is a little bit of my code that you might be able to figure out what I am doing wrong.
Current error on the line below states: Object doesn't support this property of method.
"hybridShapeIntersection1.GetCoordinates coord"
Creating the Intersect:
Code:
'Make an Intersect
'Store the Intersect in the Intersects Geoset
oIntersectsGeoset.AppendHybridShape hybridShapeIntersection1
'Local Update the Intersect
hybridShapeIntersection1.Compute
Trying to Get Coordinates of Intersection:
Code:
Dim coord(2)
Set TheMeasurable = TheSPAWorkbench.GetMeasurable(hybridShapeIntersection1)
It's TheMeasurable.GetCoordinates
By the way you don't have to put intersection into a geoset to get coordinates.
Ok, I feel dumb. I must not know enough to get your direction to work Little Cthulhu.
I tried multiple things to get this to work and no luck.
I currently get Run-time Error 438
Object doesn't support this property or method.
Current Code:
Code:
Dim coord(2)
TheMeasurable.GetCoordinates coord
Also, I understand I don't have to put the intersection into the GeoSet, I just use it as a reference how my Code is currently working until I get all the kinks worked out.
I will comment out that line once I get this to work correctly.
Hi everyone,,
I was facing some issues in above macro, can you please attach some example 3d model, so that I can clear my doubts,,, please do this needful...
What issues are you facing?
I will do what I can to help you out.
I have converted this to VBA, so I have made a bunch of updates to it, but it is still in work.
I am unable to upload the model I used to test this out on because it is customer property.
Thanks you jecha,
I have L shape solid model and both side have contour surface, so I have to put holes normal to surface on both side,, what are the inputs required on above macro which you created,, could you please suggest...
FYI:
In my model below data is available
Partbody
Geometrical set (points)
Can you please suggest any other info required to run this macro
You will need the following and labeled correctly:
Contour Surface labeled "InputSurface"
Center points for your holes on the InputSurface in a GeoSet labeled "HoleCenterPoints"
PartBody must be called "Holes"
I believe this is all you will need.
I can't remember if this macro is able to handle some of the surface/points types.
Try Copying and Pasting Special "As Result" to create an isolated InputSurface and do the same with the Points in your HoleCenterPoints GeoSet.
