Multiple outputs from nested loops
lmenich
14
CA
I have a relatively long programming function containing nested loops and am trying to retrieve more than one output from them. Is there a way I can assign a value within a function as a global variable? Or return more than one output using some other method?
The output of a program can be a matrix. 'Augment' and 'stack' are two commands to get familiar with. For instance, to return multiple vectors from a program you can use the augment command to create one matrix.
output <- augment(vector1, vector2...)
Peter
