newman180
- Jan 18, 2013
- 10
I am working on a Senior Design project for Mechanical Engineering Degree, so electrical understanding is not my best skill.
I have a vehicle chassis whose two stroke engine is started with a starter motor which only has a positive lead (no negative lead). I assume it pulls its ground from the engine block as the spark plug transformer is grounding to the block from the battery source.
I am attempting to run the ignition system on a separate lower voltage source than the starter motor but I am unsure how to pursue the ground. If I were to ground the ignition/engine block to the lower voltage source with the positive lead going to the ignition transformer and also ground the higher voltage source to the engine block with the positive lead going to the starter motor, will this work?
I can't completely wrap my head around my logic, but I want to say no because I cant understand how the powered source will follow the correct ground to complete the loop.
Thanks in advance!
Thanks in advance!
