I'm looking for a tank mixing tank system suitable for a solids content of between 4- 7% w/w solids content.
We have two sludge stream coming into a blend tank and the mixing system should blend and keep the solids in suspension before being processed through our new sludge thickening facility.
I beleive submersible mixers would not suitable due to the high viscosity of the sludge and I was looking at a hydraulic nozzle jet system using a recirculation pump. In order to effectively blend I was going to pipe the two sludge streams into the discharge of the recirculation pump.
I have received one quote for such a system but it was just to expensive.
Has anyone had experience with municipal sludge (blend) tank mixing systems?
Andrew
Andrew
