gordonl
- Sep 4, 2001
- 308
I'm in the process of replacing an old 15kV metalclad lineup and am wondering what others are using for bus protection. In the past we've used graded overcurrents which gave delays of upto several seconds for solid bus faults. I'm currently looking at blocking & tripping of instantaneous elements or bus differential and would appreciate any comments on current practices and experience.
I'm leaning to the blocking method right now because of the low cost of implementation. The sub is double ended with the tie breaker normally open. All loads are cable feeds to transformers.
